rosedale123
some more info the 1800 gas....the number on the carb as best I can read is 44890B. The number on the block ( top to bottom) 157329A, 221120G, and 1163.
The volumetric measurement of fuel flow was 8oz in 27 seconds with just gravity feed. I was not able to check with the mechanical fuel pump working as I was out of hands. I would estimate it to be 1/2 the time ( 13.5 seconds /8oz).
The fuel was clean.
I checked my float setting and from the gasket to the top of the float ( 1/2 was inverted when checking) it was 1 3/16( or very close to that) as measured with a machinist rule.
Does this help at all?
As always , thank you.
ron
The fuel was clean.
ron
