rosedale123
I am the one with the 1800 gas that starts and idles fine but when the throttle opens it stumbles and can most time be saved by the choke. Mose times when I get the rpm up it will stumble and die like it runs out of fuel. It does have a mechanical fuel pump and with the fuel line unhooked it does "spurt" when the engine in rolled over ( with the key). Carb has been thorougly cleaned and screw turned out 1 3/4 turns. When my FIL go this tractor they had an electric fuel pump installed but I went back to the mechanical pump -- do you think they were telling me something? Fuel flow is good. Does this sound like a fuel issue for sure???? Kinda perplexed.
