Good thing MinniMan told me about the piston popping out because of the discs being worn,so that I had some here before I took it apart all the way. They were toast. The outside of the outer disc had come loose and was floating. What's left of it anyway. The inside of the outer disc was gone. Nothing but pieces laying in the bottom.
I left the bottom bolts in it,but loose,stuck the air chisel in the top from behind,gave it a couple of raps and it popped right apart. I used the floor jack and a block to let it down out of there. The wife had to pump the jack for me while I steadied it to get it back up. It's all bled out,parking brake is adjusted and she's ready to go.
I just hope the last owner had a penchant for using the left brake. If not,the right one is on the critical list.
Thanks everybody for the help.
