I need some advice on what my next step should be.
I resealed both brake pistons on my 75 2-105 White tractor which had leaked out the hydraulic oil. I refilled the hydraulic tank bled the new hyd filter with the brass wing nut till clear oil appeared without the engine running. Then I loosened the out put line on the hydraulic pump allowing oil to leak from the fitting as the engine was idling. But NO pressure buildup. Only a small stream of oil flowing out of the fitting. After maybe 10 minutes there was a slight warmth to the touch of the pump.
Did I bleed it correctly? Possible fried pump?? Hope not!!!
Prior to me beginning repairs the tractor had hydraulic pressure but did run for a short time with little or no hydraulic pressure due to low oil.
Advice and suggestions will be appreciated.
