White 548 broken?
I looked at the plow again today and noticed that I could move the mast(where the 3pt arms hook up) without the tail wheel pieces moving. But if I move the tail wheel mechanism it would move the mast. Is it broken or only turn together when theres weight on it? Or is it made that way to make it hook up easier? But I think I'm going to offer 500-600$ for it.
You better look at it again. That linkage is what steers the tail wheel. You don't want that loose! You should also talk to a jockey that deals in plows. Around here that plow would be a $200 plow at best and then probably the buyer would part it out. There is a 5 bottom 566 plow setting in the weeds beside the man's barm that has not moved in 10-12 years.
No the linkage is tight, very tight. I can move the tail wheel linkage piece by hand and everything moves as it should even where you hook the three point to. But when I move the piece you hook the three point to it spins but the linkage won't move. Ill post pictures if I buy it.
