Trevor4440
What is you guys trick to easily unhooking and hooking the hydraulic lines on a 2-105? I've got a real nice 2200 hour one that I bought off a retired neighbor a few years ago. Its one of my two tractors I actively use farming part-time and I have to switch implements all the time, some use both sets. I always have one or two lines that are near impossible to get out or in. On my JD 4440 I can shut it off, cycle the lever a few times and it relieves all pressure on the lines. The White doesn't seem to do that, I end up doing every possible combo with the levers running and not and eventually I get the line to snap in. It took me an hour and a busted knuckle yesterday to switch from a 2 remote disk to a 2 remote field cultivator... I like the tractor other than that, so what's the trick?
