Putting new style fuel filter on 1555
bv
Has anybody put the newer style square glass fuel filter on in place of the older canister filter, I want to update my 1555 to this style, I would appreciate any info and pics you may have, thanks again.
You'll need the bracket,filter base, clamp and fuel lines and fittings.They're found in white 2-70 parts book. BUT, I don't know if your block is tapped for that filter base. I know the 1655 block is because mine has it. I would look at a 283 block and compare it to yours.
bv you might want to check on the filters you get-- they make 5 micron and 10 micron. memory is bad--it has been 30 years since I sold filters, I think the 5 micron were designed to have a pump in the system to push fuel thru them, Some one else whose memory is better then mine post back. I don't want you to get stuck out away from home with a plugged 5 micron filter when a 10 would have been better.
