I started plowing undera field of winter rye on Friday that just didn't look too hot, and Saturday I finished it. When I started back up on Saturday I checked all the fluids, though I had enough fuel to finish it all up. I got that field finished, and then did another 2 acre piece. I had 3 passes left, when the 1855 feel on her face and just lost all power.
Seemed like the fuel filter was dirty, but I checked the tank, because then I glanced at the fudge and it was at empty. Sure enough,I could see the bottom of the tank, with a little fuel still sloshing around. At this point even at idle it was starting to run funny, so I knew I wasn't going to make it back to the tank. I shut her down and called dad to bring me a can of fuel.
Got 10 gallons back in her and had to crank it just a hair longer than normal, but she fired up, and after a minute or 2 the idle smoothed out again. Finished plowing the last couple passes, and went to the fuel tank. While I was at it,I figured it was a good time to replace the fuel filter on the tractor. It's got the cartridge type, so while the tank was filling I shut the fuel of at the tap, swapped filters quickly, and bled it at the filter base. By the time dad came back around after unhooking the manure spreader from the other tractor, I was full and had it running again. Easiest tractor I've ever had to bleed.
Donovan from Wisconsin
