Oliver 60 engine wet or dry sleeve
old
So I have this Oliver 60 engine in a Cletrac HG. Sort of need to mess with it due to the flood we had plus it was getting water into the oil. So figure I may need to pull the head and if I do if it is a wet sleeve engine might as well replace the sleeve seals if I can fidn them and a gasket set
I think I have a set of sleeve orings and a manifold gasket. You can have them if you want them.
It's a wet sleeve engine very similar in design to the Allis Chalmers 125 engine. Maibach Tractor in Creston OH can get you anything you need for a 60 tractor or engine. I got everything to overhaul my 60 from them.
