Need some help, have 2 1850's and a 1950 t, on the one 1850 everything in the hydraulics works fine the other and the 19 I can't get the baler door to shut unless I hook the remotes what I consider backwards and the 19 is slower than molasses in picking up a haybine. I have turned in out and everywhich way I can to no avail. I am asking on here as my dad is no longer available to guide me through fixing the problem. Now for the confusing part for me the 18 where the hydraulics work has an over under, under works and over works but it will not hold back in direct and I don't understand what has happened, it will eventually get torn down but not at the moment is there something I can do to rectify this problem.
