77 air force tractor
rustyplow
Bought this worn out old beast today. Parts most likely, but we'll see. It is loose yet so may run with a little help. Loaders got to go though. What a heavy, clumsy thing.
Hey, that's a good looker! Very interesting! Do you have any other pictures of the loader? I bet it wouldnt be that bad if it isn't all cobbled up. Probably a desirable thing for someone with an industrial Oliver. Try to get it running, shouldn't be that bad if it's free. I've brought stuff back a lot worse than that. I've had to scoop the rust out of the dirt to have enough metal to put some tractors back together lol.
Ross
   It's a super, has Oliver stamped in the fenders and the large opening in the hood.   Should you part it out, it will have the high speed 5th and 6th gears in the transmission.
Well, that's what I did. Just not sure what to do with it now. Wife said I just added it to the inventory of projects I'm pretending I'll get to some day.
I would be interested in the right rear fender if you part out or maybe whole tractor you can call anytime 918 633 3248
