oliver 1755 steering
TP in IA
My 1755 has developed a oil leak in the dash ,oil leak seems to be up where u can't see I removed side panels ,can't see where its leaking at .my question how do u go about getting into dash below the steering wheel to find leak THANKS TP
Need to pull the fuel tank out. And hold on to your wallet because those houses aren't cheap from the dealer, and most guys replace all houses while in there because it's a pain to get to. A good hydraulic shop may be able to make you the lines, but they need to be identical and some of the fittings required still aren't cheap from a shop.
Did the houses on our 1855a number of years ago, think it ran around $3-400 for all the hoses. I want to say there were 5 that I replaced.
Donovan from Wisconsin
