I have replaced the O-Ring #39 Page 214 in the Agco parts book but it continues to leak a steady drip when the engine is running. The size of the O-Ring is 3/32x11/16. It doesn't show a metal back up ring like is found on the O-Rings between the valves.
This opening returns the hydraulic oil to the differential after passing through the remote valves. Is it under high pressure? Would putting an O-Ring and making a gasket work? I am not sure what else to do to stop the leak.
Thanks for any suggestions.
