A couple of questions about hydraulics on a new to me 1850 gas row crop, but probably would apply to other 50-series as well.
1. Is there a way to adjust hydraulic levers/valves for proper neutral setting? I've been running the tractor some while doing a tune up and have been getting a large puddle of oil coming out of the right
remotes when things are supposed to be in neutral. Which to me indicates that the valve spool is shifted enough to be sending oil to the remote. Otherwise, shouldn't oil in the remote lines just be trapped
and not under pressure to cause a remote to leak?
2. And for a simpler question that I should know, for the two ports coming out on each side of the hydraulic unit that serve the rear remotes (tractor has two sets of remotes) which port is pressurized when
you move lever forward vs. moving lever back?
Thanks in advance for any help!
