Got the 105 running this morning after sitting all winter. Started working up ground. Ran good all day. All of a sudden-no steering. Hydraulic outlets worked OK. I could raise and lower the disc as normal. Brakes were good and PTO started and stopped as it should. Hydraulic reservoir was full but the fluid burped out the opening when I checked it after unhooking and shutting tractor down. Fluid seemed hot too.
Any ideas as to what to check? Also, noticed a clicking sound coming from the pump instead of its usual whine. Would the pump getting weak and making the fluid hot cause the steering motor to act up? Any ideas would be appreciated.
I have had a lot of issues with the hydraulics on this tractor- replaced all seals on PTO and pump and rebuilt the outlet valves too. Finally stopped losing fluid and had full pressure for the slave cylinders. Thought my problems were over, now this!
Thanks.
Thanks.
