1800A Tranny
JEH
I have a 1800A that the 2nd and 4th gears jump out of gear.
I have had a suggestion that replacing the rear end would be easier than replacing the tranny.
I would like to know which tractors rear ends will fit the 1800A?
I'm also open to other repair suggestions
You may want to at least pull the top cover first and investigate why its jumping out of gear. Could be something as simple as a bent shift fork.
If the problem is 2nd & 4th the problem may be in the shift forks or you may have excessive movement of the gears on the bevel pinion shaft. Has an oil pump to pressure lube the transmission been added to your tractor? You have e-mail?
(quoted from post at 18:21:53 05/10/16) If the problem is 2nd & 4th the problem may be in the shift forks or you may have excessive movement of the gears on the bevel pinion shaft. Has an oil pump to pressure lube the transmission been added to your tractor? You have e-mail?
I think it has been added
My email is [email protected]
