I know the 1655 has a 12" clutch and the 1855 has a 13". Both use basically the same block. (for starter location) Can a 1655 use the 13"? If not a direct fit, can a flywheel from the 1855 fit in the 1655 housing? We are wanting to add a little beef for plow days by using the 310 crank as well as turbo, complete assembly built right and balanced. I am sure the stock clutch will be the weak link if I have to run a 12" so may have to go to someone that makes pulling clutches if that is the case. I have also built or worked on a few other colors with double disc clutch so that may be another option.
