chargerguy
Finally getting close to done with this tractor. Clutch is in over/under resealed looked in transmission
all looks good and tight all new oil though out. Started tractor all is well Until fuel shut off broke
discoverd had oil leak under cab got tractor shut off. Tightened fitting and storm came in. Stopped for the
night came back today added oil replaced shut off cable. Started tractor. No hydraulic. No steering
nothing. Loosened air release on filter housing oil runs out no air. Only lost about 6 quarts and didn't
run long. Did setting overnight let air go up to something? Can't hear any pump noise yesterday had some
air going though. Didn't run more than 5 minutes overall. Just moved it in a u turn and backed it up and
checkedfor direct drive. Noticed oil leak and stopped. Now no hydraulic. Thanks for any help
