Will a Super 77 cylinder head fit on a 1550?
'67 1550
My 1550 diesel cylinder head (casting #186402K) has some bad cracks, not just around the injectors but between the valves of #1 cylinder and between #1 and #2 cylinders. Will a cylinder head from a Super 77 diesel (casting 186402) fit? Thanks!
Yes, but your exhaust valves may not fit. You have a phone number and I will explain it but I need to look in my book first. J.
I'm not sure what's going on with that, I have it enabled. Do you know if the intake and exhaust valves are the same on the two heads?
The Super 77 head Oliver number is 1M-180-H and the date is 12-54.
The 1550 head Oliver number is 162122AS and the date is 2-66.
For the email, click on "emial" at the bottom of this post, when the email screen comes up put in your email and the message. I tested it earlier so it should work.
Thanks again!
