spin out wheels
880 Oliver with spinouts loaded and the rims are ruined . How does the rim seperate from the cast center? I have all the big nuts loose but the studs dont seem to retract far enough to clear the rails. What am I missing.? Thanks
Look for a small flat spot about 2 inches in from the edge of the cast wheel. You will find a small roll pin. Knock the pins out and the studs will go into the cast wheel a little further.
