I have a 4-150 white that i am working on and they hydraulic reservor in the back is leaking into the transmission. I have replaced the
hydraulic pump because it was worn out, then i took the charge pump and replaced the seal and 2 o-rings. I also took off the hydraulic
Reservoir/ rockshaft housing to inspect the metal pan underneath. I poured water into the pan with no leaks, so i replaced both gaskets and
put everything back together. The reservoir still leaks into the transmission, and it seems to be leaking while sitting as i drained the
transmission and it is gaining oil over the weekend. Just looking for some advice thank you.
