OK,I want to make sure I'm safe in assuming the grille from the earlier 2-105 without headlights in the grille will work in the later one with headlights. What is the real difference? Is it just that the 30-3371344 late one has the emblem held on with screws instead of being molded in to the plastic?
I took the one off mine to try to patch it with fiberglass. The number is stamped in the back side. It isn't the number it should be according to Agcopartsbook. It says 30-3141179 and has the WHITE lettering molded in to the plastic. In the book,that's for before serial 276762. My serial number is 293141 and should have that later 30-3371344 grille. Mine has the headlights in the grille. Agco parts shows the one I have,used without headlights.
Here's the kicker. I was doing another search and found a place that supposedly has one of those later 30-3371344 grilles. I didn't want to call them,find out they have it,pay God knows what for it,then find out it's different.
I'm totally confused.
