oliver1755
Would a bad solenoid lead to a 1650 gas not shutting off when I turn the key off? It was not wanting to turn over well, and I found that the cable post was a little loose at the inner nut. I tightened this and it started turning over well, but the key will not shut it down now.
It's a delco 4 post solenoid, mounted on top of the starter. From outside in, one large post for the battery cable, two smaller ones that I didn't trace the wires too yet, and the large one on the inside that hooks to the starter feed.
The battery tests good, connections good there now. The key switch is basically new, but yes, they can fail. It shut it down fine before messing with the solenoid.
Thoughts appreciated!
