Warrenoliver
New User
Getting ready to pull the engine on my 77 gas tractor. I have everything removed everything except the clutch linkage and the return spring. How do I disconnect the linkage? I see the clutch rod coming from the bell housing is attached to the long linkage connected to the clutch pedal but I won't be able to disconnect at that point because the linkage rod has a 90 degree bend. Do I just pull the whole 3' long clutch linkage out when I pull the engine?
How do I disconnect the clutch spring? It is under a lot of pressure and I don't think I can get in there to detach from the frame under the belt pulley gear case.
Thanks.
Warren
Thanks.
Warren
