Jake Collie
I have an 1850 diesel with hydra-lectric. My field cultivator bounces when I lower it so I thought I would adjust the restrictor valve per the book. The book shows a lock nut with a threaded rod with a slot in the end to be turned with a screwdriver. In the pictures you will see that I have some hex head pieces where the threaded rod is supposed to be. Are these pieces just covering the rod to save the threads or do I have something different? The hose goes to my power beyond and I think I should be adjusting the hex head on the left side above the hose for restricting flow. Is this correct?
