Thee Ol 55' is a runnin again.
ol 55'
Well went out to start and run that there 55' after about 3 long months tearing down seals, O rings in the center frame, changed out the clutch, throw out bearing, seals in the brake cross shaft, seals in the upper Lift arms rebuilt the pump, new driven plates in the pto, etc. etc., couldnt have done without the help of you good American Farmers Thanks alot all of you. :D
