I recently aquired a 1650 diesel from a neighbor and not being real familiar with Olivers, have a couple of questions. How do you let the
pressure off the hydraulic hoses to disconnect them. I think it may have had the electro- hydraulic, because there are some wires near the
levers that are cut off, if that matters. It also has been changed to iso tips. Does it do any harm to use it continually in hydra power
drive, or should it be used in direct and the hydra power only when you need to slow down or need extra power. Thanks Mike
