Roosamaster pump conversion
Benelli
I have an 1550 diesel with a cracked block. I also have a super 88 engine with a Bosch pump that needs rebuilt. Is there a way to use the roosamaster pump and parts from the 1550 engine and convert it to the super 88 engine? Thanks for any help. This will eventually be put together for an engine for the 1550.
It should work fine, transferring all the timing case and gear parts from the 1550 to the 88 block. Roosa pumps turn 1/2 engine speed, American Bosch PSB pumps turn crankshaft speed so the gear train is different.
Don't forget I have a good Super 77 block with good Bosch pump if that helps you.
Rod maker I am not sure about the head on this engine but I am in need of it for another project. Sorry I can't help
