Shifting rail alingment?
ol 55'
Can't seem to get the 3 rails lined up to shift the transmission. I have the top cover on with about 4 bolts to locate it and with the shifter out I'm using a big heavy screw driver to adjust them back and forthe along with the rear jacked up a bit off the ground. Just checking to see if someone has a picture of the alingment or a procedure you follow, all 3 rails slide back in forthe on my 55 6 speed. Thanks there farmers.
