I'm wondering if anyone has hooked up the power beyond flow on a 50/55 series to serve a set of remotes. I've got an 1850 that has an external loader valve on it plumbed into the power beyond flow/return. Tractor no longer has a loader, so I'm going to remove the valve. I'm toying with the idea of connecting the power beyond pressure/return lines to a set of remotes for use with attachments, such as my post pounder, that require a constant flow (and have their own valve).
I'd just use a short jumper hose to connect the power beyond remotes when not being used for something else. Anyone else done this?
