Anyone had problems getting the engine assembly w/over/under to slide back together? Lacking about a bolt hole from fully slid together. Been turning engine by hand while going in so the thing wouldn't bind but can't get last little bit. Thanks craig
Put the transmission in gear to keep the input shaft from turning. Turn the engine in normal rotation so sprag in the over/under grabs and turns the output shaft. My guess is the splines haven't lined up. The coupler/splines are good for about 3/4 to 1"
