Need some independent thinkers to give me some guidance on the value of an 1850 gas. This tractor is mechanically sound. Starts and runs good. Tranny is quiet and shifts into each gear. Hydra Power works but the shift mechanism binds. Sheet metal is straight. Hydraulics and pto work. Front and rear weights. No leaks.
On the other side, it has a "30 foot" paint job...meaning it looks good at 30 feet. Decals are not correct. Gauges are miss matched. Lights do not work. Tires are mismatched. One rear and one front are shot. The other two are good. Missing the battery cover. Tilt steering does not work...pedal broke off. Brakes need replacing.
I know what they are asking for the tractor and it seems high for one that is far from perfect.
What do you think this would be worth?
