Okay, i posted a couple of weeks ago about the balancer on my Perkins. Got it apart yesterday, pictures attached. The splines on the crank are pretty buggered up. The balancer has had a smooth bushing pressed into it and they tried to squeeze everything together using a tapered washer. The washer broke into 4 pieces. So i assume the balancer is supposed to have a splined sleeve. If it did, is there enough spline on the crank to make it work? Somebody mentioned a compression washer, is that what i need to try here? The threads in the end of the crank seem to be okay. Advice would be appreciated, thanks!
