66 row crop
roy prins
the motor wants to surge when you get off idle speed -- took off the governor all looked good -- set to the manual specs on the linkage -- what next ? sounds like its trying to bale hay -- any thoughts?
If this is at no load then it could still be the bumper spring as suggested. The carb is open very little at high idle.
RT
