Will my 88 pull this?
Nick167
Will my 88 pull this with the right weight the guy that has it pulled it with a 756 farmall sounds like I can get it for a couple hundred thanks
I would pass on it!. FYI for you do the deep tillage (chisel plow) in the fall in this and your area. that is more of a bedder. Didn't know they made them in Martin, probably for tomatoes at one time.
I thought it was odd looking for a chisel plow if he sells it to me cheap I might get it just because I've never seen another one
If you can buy it cheap enough, take those disks off and you might be able to pull it 6" deep. Take a couple shanks off and go deeper, but you won't be wide enough to take out your tractor tracks. Just my thoughts. Chris
