1650 hydraulics need help
Neighbor has 1650 that 3 point is weak
and gets weaker with time used. I checked
the bypass and relief valves and all was
well. Plugged pressure gauge in one of
the remotes it reads 1000 psi. It needs
a new pump doesn't it?
More than likely yes. My 1800 got weak, a new pump from all States Ag Parts cured it. That was before I knew I could parts from here.
Every new pump I look at says "if old pump has cast iron discharge with relief valve application will not work".
How many tractors had that type pump and what to do if you have one?
