White 2-135 Stop Engine light
My Stop Engine light came well I a was chisel plowing today everything seemed fine. The alternator is going out so that might be a issue. What would cause to come on?
(Don't have a manual yet)
Thanks
Strong Olivers
That light is connected to a sender for oil pressure. It uses its own sender by the engine block the gauge sender is round with a diameter of about 1 1/2 inches and is about 1 1/2 inches long the one for the light is much smaller. Unplug that wire if the light stays on you have a bad spot in the wire. With the engine running and oil pressure registering unplug it if the light goes out you have a bad sender.
I believe the there is a high water temp also on the same circuit as the low oil pressure. If the wire or sensor grounds, the light will come on.
