whitehotrod
New User
I went through my over under tranny in my 2-105 white tractor. I have it mostly assembled and am following the repair manual. The manual has indicated to follow a procedure to apply air to the oil ports to check the clutch engagement of the over, direct and under clutch packs. It has indicated this be done with the housing cover with the oil pump off. I performed this procedure and the overdrive clutch seems fine, the direct drive clutch works fine, although it seems to be leaking air when I test it. Anyone know if this is normal when cover is off, or does it not make a difference?
A different situation I encountered is there is a little spring that came out of somewhere that is about the size of the spring in a pen, although a bit heavier. Any ideas where that came from?
Thanks for any help.
