1850 bottom transns shaft w? spline for 4wd
Cas
Ebay has a 1850 lower trannsmission shaft and the fellow selling it wants $1300 or best off. It has the splined extension for a 4wd drop box. What might a reasonable amount to offer for it? I was going to use it next year for a future project.
Consider that the differential pinion gear is on the other end, and it should be matched to the ring gear. Is the ring gear also available?
Oliver sold the ring gear separate from the pinion shaft, but get a tooth count as I don't remember if all 1850 FWA models had the same tooth count.
I have a long pinion shaft with matching ring gear and collar for transfer case out of a 1950 for sale if you don't buy the one on ebay. If interested you can call me (606) 776-4034.
