Oliver Super 88 engine
Chris5
quick question before I order some parts. Looking to put 3.875" FLATTOP pistons in my super 88 gas. If I buy a sleeve and piston kit for a 1600/1650, Will the sleeves work in the super block without machine work? How about the pistons, will they need any custom work to use with my stock crank and rods?
You need to be a little more specific. The sleeves will fit. Now if the flat tops are for an older 1650 diesel they are taller than Super 88 pistons. Check the compression height.
I was looking into buying the kit that YT sells, PK311. Do you happen to know how much I need to have milled off the top of the piston? I am going to use a 1650 head to help bump compression a little as well. Email is open or my # is eight six zero-759-0183 if thats easier.
Thanks
