1465/1365 Blocks
Traditional Farmer
Location
Virginia
Does anyone know if the blocks on a 1465 and a 1365 will interchange into either tractor?
I know the internals are different just wondering if I can swap out the whole engine?
That's a good question , one I don't have a good answer for! Only thing comes to mind is call the guy in Canada , import tractor parts , he seems to be really knowledgeable on those fiats.
You're not getting a lot of solid answers, so will just say "I doubt it" because I have seen both 1365 and 1465, and the 14 seems like a substantially larger tractor- so its not like some where they give a new model number because they turned up the pump or turbo-ed it. The other suggestion to get ahold of Danny at Import Tractor Parts is a good one.
I just remembered I have an old tractor spec book. It shows the 1365 with a 210.9 cu. in. engine, and the 1465 with 278 cu. in. Too big a difference to do both on the same block. That said, I don't know about the outside dimensions, flywheel bolt pattern and motor mounts.
