oliver disc model
MikeinKy
What model 10 ft disc would have been sold new in 1966 or 67 with a new 1650 tractor. I recently aquired the tractor and disc and all of the
decals that I can read say Oliver. It is original, never been repainted.
Also right before the 250 series were the 240 series. Also there was a difference in blade spacings as well. In fact we sold a few that had the wide and narrow spaceings on one disk as per customer request
The 240 & 241 series have a front channel iron beam that is "bent" (center farther forward than outboard ends). The 25X series the front beam goes straight across.
Thanks guys, I will get a picture tomorrow. I grew up with red and the other green. Oliver is new to me.
It must be a 240 something. It has a rounded front and 20in. blades with a 7in. spacing. I'll try to show a picture.
I was wrong. When I went into the parts book the 251 had the 240/241 curved front bar. It appears to be a 251 when you look at the drawbar system and the adjusting crank. The White tillage is in AGCO under New Idea, not White.
