I looking for some info on putting larger sleeves & pistons in a super 77 gas. I have herd to stay away from the M&W because you loose compression and power.. is that true with the new ones from korves as well?
This is going to be a pulling tractor but I would like to still run coolant in the block. I have herd you can use 88 sleeves and get the block bored. What else do you need to do in order to do this? Do any of the sleeves need to be turned at all or what issues might I run into? Would any other sleeves work or should I have some made? I have been having trouble finding much info on this.
I have a few other things in mind I will be doing to it as well.
