oliver 770 power steering
I have a friend who is going to look at a 770 and the current owner said the power steering is not working properly. what are the common problems associated with the power steering on a 770? thanks
Well first of all there were 2 different power steering units. You need to tell us if it the early or late type unit. So how about a tractor serial number and then if there is a solid shaft from the steering wheel down to the steering unit or if 2 steel lines go from behind the tan and then go the steering cylinder under the radiator.
I haven't seen the tractor yet but he said it had the power steering pump near the generator so I would assume it to have the solid shaft and not a char-lynn or the likes?
I will have to get back with you for that info. we are going to look at the tractor Friday morning. was just wondering if there were some common problems? I know my old 1650 I had to turn to the left constantly if I ran it down the road but it had a char-lynn unit.
