Pilot bearing.
ol 55'
Looking to install a new pilot bearing prior to my clutch plate and disc. Basically on my super 55' there was a snap ring then it came out rather easy thinking there seemed to be no real press fit what so ever. Now should I just add a little adheasive , say permatex or something before I install it? Thanks there Farmers.. :?:
How loose do you call loose? I would not use the Permatex, maybe a drop of Locktite if is very loose or take the hub off and dimple the bearing bore.
