Oliver OC3 and Cletrac HG TRACKS
Hello,can the Oliver OC3-42 tracks be interchanged with an CLETRAC 42 HG?? My tracks are pretty worn on my OC3-42 and at its limits. I can buy a CLETRAC HG 42 with good tracks but hasn't run in a long time. They pretty much look like the same machine, the CLETRAC doesn't have a water pump on it. Thanks!
The HG , OC3, OC 4 and OC 6 use the same tracks. The number of links may vary as some machines had 3 and other 4 roller track frames.
Count the number of links of the tracks on each machine to be sure they are the same. If the ones that are well worn are one link shorter, that is likely due to one link being removed to keep the front wheel in the track frame!! This is often done to get some more use out of worn out tracks.
