Delsfarmllc
New User
I have just recently acquired a 1965 Oliver 1550 gas tractor. I got it home, charge the battery, and it fired right up. You can grab the shift lever and put it in any gear that you want. So I push in the clutch, fired it up, let go of the clutch and it went in reverse. While it was running I pushed in the clutch, grab the shifter and put it in what I thought was neutral, and it still went in Reverse. While the tractor is running, I can either put it in neutral or reverse but in either position it still goes in reverse. But when the tractor is off I can put it in any gear that I want and you can feel it pushing itself into gear. So my first thought was shifting forks. So I pulled the shifter and shifter housing off so you can look down on the shifting forks, my only problem is I don't know what I'm looking for any help is appreciated. Thanks and God bless
