1850/1855 input shaft
rrlund
Just for future reference,is the input shaft for the over/under and/or hydra power the same on an 1850 as on an 1855?
In other words,if you swapped the front tub and Perkins engine from an 1850 over to an 1855,would the shaft from the 1855 over/under work on the Perkins?
Don't think so.
I wonder if you could use an 1855 clutch and pilot then with the 1850 flywheel and get the job done?
