Front and rear main seals for a 99 Oliver
Chrissub
I need seals for a 99 Oliver. I think it has a 310 engine. Napa cant seem to find them. Anyone have a part number? Thanks
Chris, you should be able to go onto agcopartsbook.com and find the part numbers you need. As you may see I've been going through the same process with a Super 88 Diesel and got the part numbers from there. I would bet Mark at Korves Oliver would also be able to help you and have the parts you need. Regards, Nate
First of all do you have an engine serial number? All the rear seals are lip type seals, however you need to determine if your tractor is set up with a wear sleeve or not as the 2 seals have different inside diameters. On the front seal, if you have an early engine it will use the same seal as an 88 if not it will use a lip type seal, so we need an engine serial number and a casting number off of the front pulley.
