saginaw vs char lynn
tntractor
I think that my saginaw power steering motor is shot. I think that there is a char-lynn on a 705 uni system out in the weeds. Will any, or most, charlynn units work? I realize that is is NOT a direct bolt in change. I am talking about pressure and flow. I will have to make up a bracket, adapt spline and hoses.
tia
I won't be much help, but I'm pretty sure that I was told the steering unit off of a MF 750 would work on a Oliver. Could you get to a Char Lynn page and see what different tractors use the same hydra motor? I'm going to scrap a MF 550 and save the steering unit for my 1850 if I ever need one. Chris
I have a 750 combine that looks like it will not sell soI might part that out as well as the Uni. Thanks for the reply.
